Uppdateringar SWEA-projektet
Startat av MrLibertad, 2013-10-29 17:33
MrLibertad Affärsomdömen
Här kommer det en liten uppdatering över vad som händer borta hos Pobjoy, 281:an mailade häromdagen då "drygt 3 veckor" veckor nu har passerat och svaren från John finner ni nedan.
Dear John
How is our project progressing? It's now four weeks since your last
e-mail, and we are starting to notice some signs of dispair among several
of our investors. Do you have any information I can pass on to them to
calm them down a bit? Christmas is also aproaching and it would be a
disaster if we don't have managed to cross the finish line before then.
Please let me know the present status on the Swea as soon as possible.
Regards
"Dear *
I'm sorry for the continued delay.
Although the plaster image I sent you was acceptable from a design point
of view, there were technical problems with it when it was received here
and it was rejected.
Since then I have received a second plaster which has also been rejected
and was returned to the sculptor on Friday of last week.
We are determined that the final die will produce a coin which you will
all be happy with which is why we keep rejecting the plasters.
I am at fault in not updating you on developments for which I apologize
but I am confident that the finished coins will be delivered before Xmas.
Regards and thanks for your patience.
John
Dear John
It is of course very good that you set high quality as the #1 goal, but
does this affect the artistic appearance? Is it the same plaster that is
redone or is it completely new ones?
Why I ask is because if you may give me some kind of details about the
nature of the technical issues, I can present if to the investors.
This would be much better ond more interesting than just sayin "they are
working on new plasters". There is also a great interrest regarding the
process amongst the members (my self incl.).
Information is often the best way to fight rumors when people is starting
to think in the wrong directions.
And last but not least, do we have any more specific timetable than before
X-mas
Regards,
Dear *
Basically, although the plaster image is fine, the way in which the
lettering is cut means that it is sloping inside the incuse base. This
means that the cutter will not give a clean cut when producing the hob.
In addition, the relief is too low and the first plaster was too thin.
Effectively, there will be a new plaster produced with the lettering
produced in a different manner although the internal design of SWEA and
the Lion will be transferred from the previous plaster.
I'm waiting to hear when the final plaster will be back with me and you
may be assured that it is our wish to clear this job at the earliest
possible juncture.
I can't give any positive date until we are happy with the final plaster.
Regards
John
Silver Affärsomdömen
Tack för den uppdateringen, uppskattas! Ska bli så kul att få se det färdiga resultatet.
norpan Affärsomdömen
Den som väntar på något gott väntar aldrig för länge!
kristensson Affärsomdömen
Dom verkar ta det där med Kvalite på allvar - det lovar gott
2818181 Affärsomdömen
Ja, det verkar som de nu är fast beslutna att inte begå samma misstag en gång till, men de har problem med den nedsänkta texten i den upphöjda randen. Jag ser dock inget alternativ till att låta Pobjoy göra sitt jobb, även om det innebär ytterligare förlängning av tiden.
Jag vill även poängtera att jag inte upplever det som att ni misströstar.  Det är snarare en taktik för att belysa vikten av att projektet går framåt.
Att dom känner vår kvalitets medvetenhet kan ge en fördröjning nu.
Men när/om vi beställer fler gånger från dom så har vi igen det arbetet som nu läggs ned.
Tack för tappert kämpande och omsorgen om ett bra resultat
the-end Affärsomdömen
Citat från: kristensson skrivet 2013-10-30 12:48
Ja, och Sweasidan på myntet kommer förhoppningsvis att återanvändas framgent, vilket innebär att när Pobjoy väl löst teknikaliteterna så är det fortsättningsvis bara att köra på.
I ärlighetens namn så flaggade Pobjoy tidigt för att det finns svårigheter med den nedsänkta texten, men de sade samtidigt att det var genomförbart. Vi har dessutom redan fått en väl genomförd skeppssida med liknande text (dock inte riktigt lika "tätskriven"). Vi såg även några mycket vackra mynt i Pobjoys utställningsmontrar med liknande utförande. - Så det må vara svårt, men omöjligt är det inte.
Det är ju samtidigt en läroprocess för mig personligen som aldrig tidigare har formgivit något liknande för prägling i silver, och det är närmast omöjligt som "novis" att se graden av svårighet i de olika momenten.
Hur som helst, så det är nog klokt att dra lärdom av erfarenheterna och försöka undvika denna typ av design fortsättningsvis. Det går givetvis att göra vackra motiv utan att krångla till det för präglaren på slikt vis.
Nu är dock tärningen redan kastad och Pobjoy kommer givetvis att lösa problemen, även om det är till priset av några extra gråa hårstrån på våra skalpar. Det är ju väldigt frustrerande att behöva vänta så här.
Vi arbetar dock vidare med övertygelsen om att allt löser sig på ett bra vis och att det blir en fortsättning på projektet. 2014 håller för närvarande på att ta form i datorn och kommer att vara klar att presenteras när alla 2013 Sweor har anlänt till sina respektive ägare.
Lordsinner ställde tidigare en mycket berättigad, fråga som jag misstänker att de flesta har funderat över.
CitatTror ni att SWEA leverans sker innan jul?
Då jag själv har planerat att lägga en bombmatta med Sweor över släkten, så är jag i högsta grad själv intresserad av svaret.
Det ärliga svaret är att vi tyvärr inte vet.
Jag fick mail från Pobjoy idag där de hävdade att det är nära nu (jag lägger ut det lite senare ikväll så att alla kan läsa). Huruvida det är korrekt är omöjligt för oss att konrollera.
Vad vi dock vet, är att vår konversation i somras tog skruv, och att de nu är mycket måna om att det blir rätt denna gång.
Vi kan tyvärr inte göra mer än att lita på vad de säger.
Till er som planerar att ge bort Sweor i julklapp, så funderar jag på om det är möjligt att ta fram en nödplan.
Just in case...
Eventuellt så skulle jag kunna ta fram ett snyggt juldokument (med bild på prototypen) som kan skrivas ut på en fotoskrivare.
Det är givetvis inte lika roligt som thé "real deal" och innebär ytterligare merarbete, men det skulle kunna vara en möjlig väg att gå.
Delge oss gärna era tankar kring detta.
Min bedömning är dock att det skall lösa sig, men vi vill tyvärr inte lova något vi inte vet om vi kan hålla. - Tyvärr.
Jag kan f.ö. berätta att jag faktiskt fick ett paket igår från Pobjoy. Överlycklig så öppnade jag paketet för att stirra på deras,.. julkatalog.
Är det inte straffbart att göra så???
Jag får se om det går att stämma företaget för sveda också värk.
Här är vår senaste konversation.
Jag tänker ge honom max en vecka till. Därefter så får vi nog höja röstläget något.
Citat från: 2818181
> Do you have any updates regarding our project?
> It would be interresting to hear how things are evolving.
> And for the record I will also repeat my offer to make some changes in the
> design.
> If you feel that it is close to impossible to achieve the highest quality
> with this design, I can redesign the lettering to a more conventional look.
> Even if it's not my first choice, It might be a better solution compared to
> an unrealistic working effort for Pobjoy and the risk of even more delays
> for us.
> "Just for the record", as I pointed out.
> Regards//
> 2818181
Citat från: Mr Smith at Pobjoy
> Dear 2818181,
> It's not the design, it's the manner in which the plaster has been made.
> I'm told by the sculptor that the plaster will be with me shortly and I'll
> will then ensure that production of die commences quickly.
> Regards
> John
Sarek Affärsomdömen
CitatI'm told by the sculptor that the plaster will be with me shortly and I'll will then ensure that production of die commences quickly.
Det låter ju lovande. Då skall vi nog ha Swea hemma innan Lucia skulle jag tro.
One month to go...
Citat från: Sarek skrivet 2013-11-13 21:00
One month to go...
Det vore alldeles ypperligt!
Det skulle kännas jobbigt att behöva dra på sig pälsmössan den 24/12, borsta av släden och personligen åka runt till alla som har önskat sig Sweor.
Kanske vi skulle kunna delegera den uppgiften till Mr Smith i så fall? Han har väl ändå inget för sig förrän den 25:e.
Apropå swe(d)a och värk, fanns det något intressant i deras Julkatalog?
Citat från: kristensson skrivet 2013-11-13 22:01
Jag befann mig förmodligen fortfarande i chock då jag inte hade förmått mig att öppna den innan du frågade.
I korthet är det inget upphetsande utan relativt konventionella mynt med:
  • Vinter OS
  • Fotbolls VM
  • Brittiska kungahuset
  • Isle of Mans Katter
  • Julmynt med röd strumpa
Om jag varit norrman så kanske jag skulle köpt myntet med Grytvikens Kyrka på Syd-Georgien.
Den var tydligen med i filmen Happy Feet skriver de, och det ser faktiskt ut att vara ett riktigt snyggt Proof-mynt.
De har även ett spektakulärt 3-D mynt med Giza-platån som motiv där pyramiderna sticker upp 5 mm över ytan.
Om det är snyggt eller ej, kan nog endast bedömas om man har det i handen.
Udda är det i vart fall.
Jag kommer dock inte att julhandla hos Pobjoy (trots att de kallar mig "Dear Priority Customer") :)
Frederyck Affärsomdömen
Citat från: 2818181 skrivet 2013-11-13 22:59
"In addition, sand brought back by Pobjoy Mint's Managing Director, Taya Pobjoy, from the site of the Great Pyramids has been encapsulated into the coin making this one of the most unique coins in the world."
1 oz silver för det facila priset av £187,50.
:o
http://www.pobjoy.com/ukworld/section.php/1407/1
